[postgis-devel] Issue 144 in postgis: Hard/soft upgrade need to be tested
codesite-noreply at google.com
Wed Mar 25 14:38:59 PDT 2009
Status: Accepted
Owner: pwramsey3
Labels: Milestone-1.4 Type-Task Component-Build
New issue 144 by pwramsey3: Hard/soft upgrade need to be tested
http://code.google.com/p/postgis/issues/detail?id=144
"ii) In terms of upgrading from 1.3, I've just remembered that Olivier
altered the signature of the
ST_AsSVG() function, plus I've altered the ST_Extent() function signature
with GBT#93. So we really
need to put these changes into the PostGIS soft/hard upgrade scripts. Paul,
are you able to take a
look at this?"
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
