[postgis-devel] Issue 137 in postgis: st_distance, shortestline (, st_maxdistance)
codesite-noreply at google.com
Thu Mar 26 02:06:42 PDT 2009
Comment #6 on issue 137 by post... at jordogskog.no: st_distance, shortestline
(, st_maxdistance)
http://code.google.com/p/postgis/issues/detail?id=137
Regina, sounds ok I think
I have commented out the longest and shortest line-functions in
postgis.inc.sql.c
Then I have made I very small change in moving some declarations because of
a
warning that ISO C90 don't want mixed declarations and code. So now I get
no new
warnings when I'm compiling.
One question:
In the function st_shortestline, if the two geometries intersect the
returned line
has both the start and the end-point in the first intersection-point. I
thing that's
a logical result and useble with st_startpoint or st_endpoint to identify
the
intersection if distance is 0. But there are severel occasions when the
distance is
0 but there is no intersection-point like one geometry inside polygon. Now
you get a
line with starting and ending at origo. That's not good. Is a empty
geometry the
best or...
/Nicklas Avén
090326.patch 416 KB
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
