[postgis-devel] Issue 129 in postgis: Test 1.4 against Windows
codesite-noreply at google.com
Sat Mar 28 17:40:40 PDT 2009
Comment #1 on issue 129 by mark.cav... at siriusit.co.uk: Test 1.4 against
Windows
http://code.google.com/p/postgis/issues/detail?id=129
I've done a build against 8.3 on Windows and it generally works, although
the
autotools output seems a little strange and the old CR/LF issue with the
regression
tests has re-appeared with the SVN move.
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
