[postgis-devel] Doxygen linking is pretty neat
Mateusz Loskot
mateusz at loskot.net
Mon May 4 03:07:00 PDT 2009
Paragon Corporation wrote:
> Strk,
>>> Also, as you noted, hyperlinking is done using the {@link
>>> method_name} tag ... I have no idea if this is respected in
>>> Doxygen though ... you'll have to experiment.
>> It's often automatic if Doxygen knows about a symbol. Not sure
>> actually about C, but in C++ sometime it'd take a fully-qualified
>> name to make that automation work.
> I did try it and it seemed to respect it. It also respects @see and
> creates a nice "See Also" section when you do that.
Doxygen respects both conventions by default, so \ and @ are
interchangeable:
"All commands in the documentation start with a backslash (\) or an
at-sign (@)."
http://www.stack.nl/~dimitri/doxygen/commands.html
> The @brief thing as far as I could tell did not work as expected (so
> might switch back to \brief)
Are you sure there is blank line after brief ?
http://www.stack.nl/~dimitri/doxygen/commands.html#cmdbrief
> or maybe the enabling autobrief messed that up.
In libLAS, we use autobrief in C++ code:
http://liblas.org/browser/trunk/include/liblas/lasheader.hpp#L183
> But my mutli-line briefs don't seem to be respected or the one I was
> looking at wasn't being respected and was just grabbing the first
> line.
There should be blank line and JAVADOC_AUTOBRIEF = NO
or you the latter is set to YES and brief documentation should
end with full stop.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
