[postgis-devel] documentation images
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Thu May 7 03:07:52 PDT 2009
Kevin Neufeld wrote:
> Hi all,
> I just committed some code that can generate most of the spatial images
> used in the documentation.
> Before, the image_src directory contained some svg files that were
> "supposed" to be the source of the png images used in the docs.  But I
> know of no way to import svg into PostGIS, I can't import them into JUMP
> to test or regenerate the svg ... they're pretty useless.
> So, I wrote a small program that will parse WKT files in the same
> directory using the liblwgeom module.  Then, using ImageMagick,
> automatically generate the png files of interest.  The advantage here,
> is that all the images have the same style (fill color, line thinkness,
> drop shadow, etc) and can be changed just by modifying a few variables.
> Because the files are simple WKT, it's easy to modify the images or
> generate new ones.
> It's written in C, and my C skills are still on the upward learning
> curve :)  Can someone who is proficient at C review the work before I
> start removing images and from SVN and relying on the app for the
> generation of the documentation? Since the code is currently isolated, I
> thought it'd be OK to submit the stuff rather have a wack of .patch
> files for someone to review.
Hi Kevin,
This looks great. The commit seems reasonably well though out and has a
nice, easy to read style with good comments. Not bad for a first C
coding effort. Here are a few general things I noticed on review:
- configure.ac doesn't check for ImageMagick's convert command
- comment in doc/html/image_src/Makefile.in still reads "Build the main
unit test executable"
More specifically for generator.c:
I see this file appears to have some buffer overflow issues, for example:
Line 315: malloc() seems to be to small; you need to malloc the size of
the filename, plus 10 chars for the "../images/" prefix, plus 1 for the
trailing zero byte to indicate the length of the string. Don't worry
about the sizeof(char) multiplier - a char is always 1 byte.
It's generally considered good practice to always use the string "n"
functions such as snprintf()/strncat() rather than the plain versions
since if the end of the output buffer is reached the output will simply
be truncated rather than causing a segfault.
Finally, use of the "rm" command on line 262 is not great for
portability; check out remove() from the standard C libraries instead.
HTH,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
