[postgis-devel] Issue 151 in postgis: 'SRID=26915; POINT(482020.9789850 4984378.)' fails to parse
codesite-noreply at google.com
Thu May 7 15:29:13 PDT 2009
Updates:
Status: WontFix
Comment #2 on issue 151 by
mark.cav... at siriusit.co.uk: 'SRID=26915;POINT(482020.9789850 4984378.)'
fails to parse
http://code.google.com/p/postgis/issues/detail?id=151
This bug tracker should be closed, although it seems if you go direct to
the URL then
it still lets you right in.
Please refile this bug on the new OSGeo tracker at
http://trac.osgeo.org/postgis.
Paul, can we schedule this project for deletion to prevent this from
happening again?
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
