[postgis-devel] WKTRaster & overviews
Mateusz Loskot
Mateusz.Loskot at cadcorp.com
Wed May 20 02:18:29 PDT 2009
Martin Daly wrote:
> > One more question: How are you going to name the overview tables?
> At the moment there is no provision for creating overviews, so there is
> no need for PostGIS Raster to have any rule(s) for naming them. In
> addition, the metadata (both alternatives) allow for discovery by query
> based on the base raster table name, schema, etc., rather than by
> naming convention.
As gdal2wktraster needs to name tables, I decided on simple convention
for that purpose, it is: ov_<RASTER TABLE>_<LEVEL> where
<RASTER TABLE> - name of table with original raster
<LEVEL> - number of overview level
Certainly, this convention sits on gdal2wktraster side only.
BTW, Since yesterday, gdal2wktraster provides support for loading overviews
as well as padding tiles (blocks) of right-most and bottom-most row with "garbage"
(nodata or zeros), if necessary.
For example, here are hex-encoded tiles of 5x5 pixels raster
(1 band, 1 byte of pixel type) tiled using 3x3 block size where
A0, B0, C0 are real pixel values and FF is nodata:
A0B0C0 A0B0FF
A0B0C0 A0B0FF
A0B0C0 A0B0FF
A0B0C0 A0B0FF
A0B0C0 A0B0FF
FFFFFF FFFFFF
Client is supposed to ignore all FFs, as they are beyond spatial extent of raster.
Best regards,
Mateusz Loskot
Senior Programmer, Cadcorp
http://www.cadcorp.com
