[postgis-devel] wktraster versioning
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Wed May 27 13:23:23 PDT 2009
Thanks Kevin,
How is "SVN" added after the PostGIS version number? We should do the
same to indicate it is the in-development version.
Pierre
>-----Original Message-----
>From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-
>bounces at postgis.refractions.net] On Behalf Of Kevin Neufeld
>Sent: 26 mai 2009 14:58
>To: PostGIS Development Discussion
>Subject: [postgis-devel] wktraster versioning
>Just a quick note to the wktraster folks,
>The PostGIS website contains links to the Raster project and tarball.
The name of the links and
>tarball are
>automatically generated by using the version info found in
>http://svn.osgeo.org/postgis/spike/wktraster/Version.config.
>Currently, the wktraster version is 0.0.0.  If this is not correct (ie.
the wiki seems to indicate it
>might be 0.1.6)
>then someone might want to update the Version.config file.
>Cheers,
>Kevin
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
