[postgis-devel] wktraster versioning
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Thu May 28 07:26:35 PDT 2009
I changed the version number to 0.1.6SVN.
The rationale behind the numbers comes from the planification.
0 means we are still in a beta process,
1 means this will be the first beta
6 means this version will contain the six requirements first described
in specs
SVN means this is the trunk
So first beta release should be 0.1.6... in september.
Next version should be something like 0.2.4. Or 1.0.0 if we get out from
beta process.
Pierre
>-----Original Message-----
>From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-
>bounces at postgis.refractions.net] On Behalf Of Kevin Neufeld
>Sent: 27 mai 2009 16:31
>To: PostGIS Development Discussion
>Subject: Re: [postgis-devel] wktraster versioning
>It's actually the micro release number
>http://svn.osgeo.org/postgis/trunk/Version.config
>--Kevin
>Pierre Racine wrote:
>> Thanks Kevin,
>> How is "SVN" added after the PostGIS version number? We should do the
>> same to indicate it is the in-development version.
>> Pierre
>>> Sent: 26 mai 2009 14:58
>>> Subject: [postgis-devel] wktraster versioning
>>> Just a quick note to the wktraster folks,
>>> The PostGIS website contains links to the Raster project and
tarball.
>> The name of the links and
>>> tarball are
>>> automatically generated by using the version info found in
>>> http://svn.osgeo.org/postgis/spike/wktraster/Version.config.
>>> Currently, the wktraster version is 0.0.0.  If this is not correct
(ie.
>> the wiki seems to indicate it
>>> might be 0.1.6)
>>> then someone might want to update the Version.config file.
>>> Cheers,
>>> Kevin
>>> postgis-devel mailing list
>>> postgis-devel at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
