[postgis-devel] Registering geometry columns
Kevin Neufeld kneufeld at refractions.net
Fri May 29 10:54:18 PDT 2009
:) It does.
Wow.  2 for 2 today :)
-- Kevin
Paul Ramsey wrote:
> Excellent! Now make it do views too!
> On Fri, May 29, 2009 at 10:23 AM, Kevin Neufeld
> <kneufeld at refractions.net> wrote:
>> That already exists.
>> Populate_Geometry_Columns() in trunk does just that.
>> Oh to be a dream fulfiller. :)
>> I just thinking to simply the user's perspective on the PostGIS metadata.
>> You're right, there are far too many management functions already.
>> -- Kevin
>> Paul Ramsey wrote:
>>> We have so so many geometry_columns management functions now. How
>>> about one function to rule them all. No arguments, it just
>>> (a) goes through geometry columns and makes sure every entry in fact
>>> exists
>>> (b) goes through the system tables and inserts every possible geometry
>>> column, both views and tables
>>> That's my dream.
>>> P
>>> On Fri, May 29, 2009 at 10:06 AM, Kevin Neufeld
>>>> Thinking about the recent question on users, I think Piotr was just
>>>> confused
>>>> about the functionality of AddGeometryColumn.  I think he was looking for
>>>> something that would simply register (or add) his view with
>>>> geometry_columns
>>>> ... which got me thinking that there really isn't a clear way for users
>>>> to
>>>> register/deregister their tables tables/views with PostGIS.
>>>> Sure we have DropGeometryColumn and friends, but these will actually drop
>>>> the geometry column or table ... not just remove a row or two from the
>>>> geometry_columns table.
>>>> If a user wants to register a view with PostGIS, do they really need to
>>>> know
>>>> the internal make up of geometry_columns and manually insert and delete
>>>> rows
>>>> from the PostGIS metadata?
>>>> Populate_Geometry_Columns(oid) that I wrote a while ago does abstract the
>>>> registering bit for either tables or views, but there is nothing
>>>> available
>>>> to deregister a table or view.
>>>> Would it make sense to add a few new management functions to PostGIS?
>>>> RegisterRelation(oid)
>>>> RegisterColumn(rel oid, column oid)
>>>> DeRegisterRelation(oid)     or UnRegisterRelation
>>>> DeRegisterColumn(rel oid, column oid)
>>>> Well, those could be the implementation functions that we can wrap with
>>>> any
>>>> number of possible APIs...
>>>> RegisterTable(tablename text)
>>>> RegisterTable(schema text, tablename text)
>>>> RegisterView(tablename text)
>>>> RegisterView(schema text, tablename text)
>>>> RegisterGeometryColumn(relname text, columnname text)
>>>> RegisterGeometryColumn(schemaname text, relname text, columnname text)
>>>> DeRegister...
>>>> Am I thinking too ESRI-ish?  PostGIS is supposed to be easy to use.  Does
>>>> this make thing more clear or does it muddy the waters?
>>>> -- Kevin
>>>> _______________________________________________
>>>> postgis-devel mailing list
>>>> postgis-devel at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
