[postgis-devel] [PostGIS] #195: Implement RFC3
trac at osgeo.org
Fri Nov 6 02:53:44 PST 2009
Reporter: pramsey | Owner: pramsey
Type: task | Status: reopened
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version: 1.4
Resolution: | Keywords:
Changes (by robe):
* status: closed => reopened
* resolution: fixed =>
Comment:
Paul -- hmm don't know what to say, except I'm really concerned about
people upgrading. This essentially requires a dump reload of the
database. I don't consider this done since you have not addressed the
upgrade process.
If you remove all those functions, then that means people upgrading from
say 1.3 to 1.4 (will be binding to their old versions) without them
knowing it. This is an unfortunate side affect of our new approach to
allow ooexistence of functions.
With that said -- the upgrade has to be able to drop the one not use and
rename the function in use and then replace.
So in short -- unless you've given great thought into this (HINT HINT my
proposed in
#202 )
I don't think you can do this in 1.5. As we have stated minor versions do
not require a dump reload though major versions can.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/195#comment:6>
