[postgis-devel] [PostGIS] #230: Put in costs in _ST and possibly other functions
trac at osgeo.org
Fri Nov 6 14:07:28 PST 2009
Reporter: nicklas | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version: 1.4
Resolution: fixed | Keywords: st_dwithin st_expand bbox
Comment (by robe):
I agree with Kevin on this. Paul I think you have gone a bit overboard.
Why can't we set just the obvious ones that have caused problems
_ST_DWithin, _ST_Intersects (and the other predicates). This is really
more of a situation problem when indexes are involved as the lower costs
sometimes makes the index operation not happen.
I'm also very concerned about the rate you are closing things off :). I
should be excited, but all I can think is "Paul, stay away from the
caffeine". When are we going to have time to test all this.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/230#comment:26>
