[postgis-devel] [PostGIS] #264: CUnit geography suite failures
trac at osgeo.org
Mon Nov 9 18:23:49 PST 2009
Reporter: robe | Owner: pramsey
Type: defect | Status: reopened
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Paul, Keep on dreaming. Just tested on my OpenSUSE 11 and same error
Test: test_edge_intersection() ... FAILED
1. cu_geodetic.c:333 - CU_ASSERT_DOUBLE_EQUAL(g.lon,0.0,0.00001)
2. cu_geodetic.c:334 - CU_ASSERT_EQUAL(rv,LW_TRUE)
Well 2 out of 4 is better. These were the two machines running newer GCC
versions (in the 4 series) that had 4 errors before. So you got them down
to 2, now just try to get rid of the other 2.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/264#comment:8>
