[postgis-devel] Multi-Lingual Docs
Olivier Courtin
olivier.courtin at oslandia.com
Tue Nov 10 08:53:44 PST 2009
On Nov 10, 2009, at 5:45 PM, Kevin Neufeld wrote:
Kevin,
>> - I suggest also to use XML entities as often as we can to
>> factorize some
>> redundant Docbook code (SQL/MM compatibility, or 3D enabled for
>> instance)
> Either that or use ENTITY variables as in top of postgis.xml for
> common text.
Yeap we talk about the same thing :)
Olivier
