[postgis-devel] [PostGIS] #293: Missed config.guess and config.sub after autogen.sh exec
    trac at osgeo.org
    Tue Nov 10 11:22:52 PST 2009
  Reporter:  jorgearevalo  |       Owner:  mloskot
      Type:  defect        |      Status:  assigned
  Priority:  medium        |   Milestone:  wktraster 0.1.6
 Component:  wktraster     |     Version:  trunk
Resolution:                |    Keywords:
Old description:
> In revision 4776, after executing ./autogen.sh, files config.guess and
> config.sub are deleted. I had to execute svn update to restore them from
> repository and then execute ./configure.
New description:
 In revision r4776, after executing ./autogen.sh, files config.guess and
Comment (by mloskot):
 Jorge,
 I can not reproduce your problem. I tried to do it this way:
  * Update and check if reported files are present
 mloskot at dog:~/dev/wktraster/_svn/trunk$ svn update
 At revision 4777.
 mloskot at dog:~/dev/wktraster/_svn/trunk$ svn st
 mloskot at dog:~/dev/wktraster/_svn/trunk$ ls config.*
 config.guess  config.sub
  * Run ./autogen.sh
 mloskot at dog:~/dev/wktraster/_svn/trunk$ ./autogen.sh
 * Running /usr/bin/libtoolize (2.2.6)
         OPTIONS = --force --copy
 libtoolize: putting auxiliary files in `.'.
 libtoolize: copying file `./ltmain.sh'
 libtoolize: putting macros in AC_CONFIG_MACRO_DIR, `macros'.
 libtoolize: copying file `macros/libtool.m4'
 libtoolize: copying file `macros/ltoptions.m4'
 libtoolize: copying file `macros/ltsugar.m4'
 libtoolize: copying file `macros/ltversion.m4'
 libtoolize: copying file `macros/lt~obsolete.m4'
 libtoolize: Consider adding `-I macros' to ACLOCAL_AMFLAGS in Makefile.am.
 * Running /usr/bin/aclocal (1.11)
 * Running /usr/bin/autoconf (2.64)
 * Running /usr/bin/autoheader (2.64)
 Now you are ready to run './configure'
  * Check if reported files are still present
  * Check if anything has changed, e.g. reported files have been touched or
 any other files removed
 At revision 4777.
  * Check if ./configure can be executed
 mloskot at dog:~/dev/wktraster/_svn/trunk$ ./configure
 checking build system type... x86_64-unknown-linux-gnu
 checking host system type... x86_64-unknown-linux-gnu
 checking for gcc... gcc
 checking for C compiler default output file name... ^C
 As you see, it works as expected for me.
 Environment:
  * Linux 64-bit (Ubuntu 9.10)
  * GCC 4.4.1
  * Autotools as installed by default using Ubuntu 9.10 packages
Ticket URL: <http://trac.osgeo.org/postgis/ticket/293#comment:2>
