[postgis-devel] [PostGIS] #299: Geography ST_Intersection -- check the brain-dead obvious before transformation
Paragon Corporation
lr at pcorp.us
Wed Nov 11 20:46:03 PST 2009
Paul,
I wasn't thinking of it so much as masking as avoiding it. Though I guess
it depends how fast our st_distance check is since mythought was we check
for intersection or bbox intersection first.
Its more of an issue when we implement ST_Difference -- if they don't
intersect the difference is clear - why return me a drifted geometry instead
of the one I gave you?
I for one would prefer things like ST_Difference and ST_Intersection be
purely C so we can handle special cases without introducing drift or bad
drift when no perfect SRID fits both.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of PostGIS
Sent: Wednesday, November 11, 2009 11:02 PM
Cc: postgis-devel at postgis.refractions.net
Subject: Re: [postgis-devel] [PostGIS] #299: Geography ST_Intersection --
transformation
Reporter: robe | Owner: pramsey
Type: enhancement | Status: closed
Priority: medium | Milestone: postgis 2.0.0
Component: postgis | Version: trunk
Resolution: wontfix | Keywords:
Changes (by pramsey):
* status: new => closed
* resolution: => wontfix
Comment:
There's two issues in this ticket: should we try to mask transform drift?
No. Should we implement the transform wrapped functionality purely in C?
Maybe, can we talk on the list about it?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/299#comment:1>
PostGIS <http://trac.osgeo.org/postgis/> The PostGIS Trac is used for bug,
enhancement & task tracking, a user and developer wiki, and a view into
the subversion code repository of PostGIS project.
postgis-devel mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-devel
