[postgis-devel] Segfault when doing intersections (BUG)
w s
forkandwait at gmail.com
Sun Nov 15 13:23:37 PST 2009
Hi all,
Summary: when doing intersections, I occasionally get a failed backend.
I am having an intermittent segfault using the st_ intersection() on some
big polygons. I will post more as I have more time, but I think I can give
enough info here to be a useful start.
I don't have a big enough machine or enough time to rebuild with all the
debug stuff enabled and keep log files, at least in the next week. With
some guidance, though, I would happily try to get a core or a gdb dump or
whatever would help. I built postgis with debug enabled and ran out of disk
space...., so I went back to the regular.
Note: I am getting errors when using proprietary data that I have
shp2pgsql'ed, so I can't provide that. The data is census tracts and
zipcodes for two states, along with associated data for populations.
I have attached a script that runs a sql script over and over again until I
get a failure. I also attached the SQL script. It always happens on the
CREATE TABLE near the end.
Log output:
pgsql[0]$ LOG: database system was shut down at 2009-11-15 12:44:59 PST
LOG: database system is ready to accept connections
LOG: autovacuum launcher started
LOG: server process (PID 29206) was terminated by signal 11: Segmentation
fault
LOG: terminating any other active server processes
WARNING: terminating connection because of crash of another server process
DETAIL: The postmaster has commanded this server process to roll back the
current transaction and exit, because another server process exited
abnormally and possibly corrupted shared memory.
HINT: In a moment you should be able to reconnect to the database and
repeat your command.
LOG: all server processes terminated; reinitializing
LOG: database system was interrupted; last known up at 2009-11-15 12:45:46
PST
LOG: database system was not properly shut down; automatic recovery in
progress
LOG: redo starts at 1/6BE203D4
LOG: unexpected pageaddr 1/657BC000 in log file 1, segment 108, offset
8110080
LOG: redo done at 1/6C7BBFB0
SQL statement at which point we died:
create table crosswalk as
select a.id as zip, b.id as tractfips, 0.0 as area, 0.0 as propzip,
0.0 as proptract,
st_intersection(a.the_geom, b.the_geom) as
the_geom, a.the_geom as zip_geom, b.the_geom as tract_geom
from orwa_zp a , orwa_tr b
where st_intersects(a.the_geom, b.the_geom);
wsprague=# select * from postgis_full_version()
wsprague-# ;
POSTGIS="1.4.0" GEOS="3.1.1-CAPI-1.6.0" PROJ="Rel. 4.7.1, 23 September
2009" USE_STATS
(1 row)
wsprague=# select * from version();
version
PostgreSQL 8.4.1 on i386-apple-darwin8.11.1, compiled by GCC
i686-apple-darwin8-gcc-4.0.1 (GCC) 4.0.1 (Apple Computer, Inc. build 5367),
32-bit
(1 row)
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20091115/bf1be737/attachment.html>
Type: application/x-sh
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20091115/bf1be737/attachment.sh>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20091115/bf1be737/attachment.obj>
