[postgis-devel] [PostGIS] #123: SQLite output format support for shp2pgsql
trac at osgeo.org
Mon Nov 16 14:23:34 PST 2009
Reporter: schuyler.erle | Owner:
Type: task | Status: new
Priority: medium | Milestone: PostGIS Future
Component: postgis | Version:
Resolution: | Keywords:
Changes (by pramsey):
* milestone: => PostGIS Future
Old description:
> Please find attached a patch that adds a -L option to shp2pgsql provide
> special-case data typing and string formatting for SQLite-compatible
> output.
> I have tested the output with SQLite 3.5.2 and it correctly creates and
> populates a table. The geometries are correctly stored as WKB in an
> SQLite
> BLOB column.
> Granted there are other ways to import spatial data into an SQLite table,
> but shp2pgsql is the fastest way that I've found to convert both
> Shapefiles
> *and* DBF files into SQL suitable for quick import into a database, which
> is very handy for piping to SQLite's in-memory databases.
New description:
output.
populates a table. The geometries are correctly stored as WKB in an SQLite
BLOB column.
Shapefiles
Ticket URL: <http://trac.osgeo.org/postgis/ticket/123#comment:3>
