[postgis-devel] [PostGIS] #313: Remove reference.xml and autogenerate from new separate xml docos
Olivier Courtin
olivier.courtin at oslandia.com
Wed Nov 18 13:09:26 PST 2009
On Nov 18, 2009, at 6:27 PM, PostGIS wrote:
Regina,
> I am totally confused. All the xmls seem invalid since they use
> strange
> new xml terms not defined so can't stand on their own. Is that what
> you
> are talking about Olivier? Where are things like &Z_support; defined?
That's the entity stuff
To avoid to have lot of redundant text, we use entities instead.
But you're right as i have to revert my postgis.xml commit,
entities are no more defined for the moment !
> I was actually thinking we don't use an xml parser to glue
> reference_postgis.xml together
Yeap that's also could be an idea.
But we have also to retrieve the entity stuff from postgis.xml
file, so no sure that will be the best/easy way to do
Olivier
