[postgis-devel] geography_columns + geometry_columns
Paul Ramsey
pramsey at cleverelephant.ca
Wed Nov 18 20:27:16 PST 2009
Yeah, I forgot about that. SQL/MM does have a different structure for
geometry_columns and does have a new-and-exciting st_geometry_columns.
Also for spatial_ref_sys.
Pull a copy of the 2004 final draft here, while it's still available:
ftp://ftp.uni-duisburg.de/GIS/PostGIS/docs/SQLMM-Spatial.pdf
P.
On Wed, Nov 18, 2009 at 8:09 PM, Paragon Corporation <lr at pcorp.us> wrote:
> Hmm on closer inspection DB2 has both a geometry_columns and a
> st_geometry_columns
> Geometry_columns:
> http://publib.boulder.ibm.com/infocenter/dzichelp/v2r2/index.jsp?topic=/com.
> ibm.db29.doc.spatial/db2z_rsbp4017.htm
> ST_Geometry_Columns:
> And the structures are different. I assume this is mandated by the MM spec?
> (though our geometry_columns looks more like their st_geometry_columns)
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
> Ramsey
> Sent: Wednesday, November 18, 2009 10:09 PM
> To: postgis-devel at postgis.refractions.net
> Subject: [postgis-devel] geography_columns + geometry_columns
> This is more of a 2.0 idea, since ideally it depends on having typmod
> support everywhere, but I am trying to think if there's any reason not to
> unify geometry_columns and geography_columns into a single view (probably
> called geometry_columns, but with an extra column to flag type differences
> for apps that care).
> In general naive applications that don't understand geography can still
> treat is at geometry-with-epsg-4326 and get perfectly respectable results,
> and that's all the metadata table is used for, so... any reason not to add
> this as a 2.0 task?
> P
> Paul Ramsey
> OpenGeo - http://opengeo.org
> PostGIS is Love.
> postgis-devel mailing list
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
