[postgis-devel] Distance ST_DWithin
Paragon Corporation
lr at pcorp.us
Sat Nov 21 10:54:39 PST 2009
Forgot to add -- I did test ST_Dwithin as well. I wasn't so much concerned
about speed as to make sure counts were the same. So I pulled some queries
from my log files and tested with the old and new to verify the counts of
records returned the same and they did.
I'll try to put together a test suite that doesn't require data, but it will
be easier to do once the patch is in so I don't have to forgoet which
postgis-1.5 I'm currently running.
Thanks,
Regina
