[postgis-devel] [PostGIS] #240: ST_SimplifyPreserveTopology documentation unclear on intersections within a MultiPolygon
trac at osgeo.org
Sun Nov 22 23:11:34 PST 2009
MultiPolygon
Reporter: perchrh | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.0
Component: postgis | Version:
Resolution: | Keywords:
Comment (by perchrh):
In the ESRI shapefile standard, a Record with shapetype Polygon is a
collection of zero or more Rings (in other terms: a MultiPolygon
containing multiple Polygons). The rings may intersect each other and
cannot self-intersect.
It is clear that ST_SimplifyPreserveTopology doesn't introduce self-
intersections and doesn't introduce intersections between Polygons if
there were none in the input.
My question, that I didn't manage to get answered by a quick look at the
code is, is the processing of these valid MultiPolygons with intersecting
Polygons guaranteed to result in a MultiPolygon with no new intersections?
Or does it just guarantee that the intersection count will not be higher
than in the input? To put it another way, if I have a MultiPolygon with
three polygons, two of them intersecting each other (A and B), is it
possible that B and C will intersect after ST_SimplifyPreserveTopology?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/240#comment:7>
