[postgis-devel] [PostGIS] #273: ST_GeomFromGML crashes in Windows compiled in MingW
Nicklas Avén
nicklas.aven at jordogskog.no
Mon Nov 23 01:40:41 PST 2009
I compiled the LIBXML2 library with a lot of warnings, do you have them too Regina or should I post them, Oliver.When I should test it I couldn't find any sql.definition of the function ST_GeomFromGML. As I see in postgis.sql.in.c that is because LIBXML2 isn't found. So I guess the compilation didn't sucess. I will see if I get time to try later today. /Nicklas
> Reporter: robe | Owner: colivier
> Type: defect | Status: new
> Priority: medium | Milestone: PostGIS 1.5.0
> Component: postgis | Version: trunk
>Resolution: | Keywords:
>Comment (by robe):
> Strange. Maybe its something else I install getting in the way or I'm not
> compiling libxml right. I have another box I can try on later. Nicklas
> -- you have a mingw install -- if its not asking too much -- can you try
> compiling and doing the simple
> SELECT
> ST_GeomFromGML('1,2')
> to see if it works.
> Olivier - what is your mingw gcc and mingw/msys versions? On my gcc 3.5
> box, I was able to compile and install without errors (except libxml make
> checks fail), but got crashes when doing the above test. On my upgraded
> mingw running gcc 4.4, I can't compile libxml at all.
>Ticket URL:
>PostGIS
>The PostGIS Trac is used for bug, enhancement & task tracking, a user and developer wiki, and a view into the subversion code repository of PostGIS project.
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20091123/8490149a/attachment.html>
