[postgis-devel] [PostGIS] #320: Upgrade scripts PostGIS 1.4/1.5 need some work
trac at osgeo.org
Thu Nov 26 08:40:07 PST 2009
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.4.2
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by pramsey):
What is the proper handling? If there's a user-defined dependent object
(note, the dependencies are not *system*-defined, I've tested all these
upgrade scripts against standard cases) what possible behavior can we
define to handle the problem automatically? The only thing left is
dropping the transaction block, which will allow a partial upgrade to
succeed and mostly work most of the time. Works for me, but then I'm a
cowboy.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/320#comment:1>
