[postgis-devel] [PostGIS] #316: IsValid called on invalid 3d object leads to crash
trac at osgeo.org
Thu Nov 26 10:03:04 PST 2009
Reporter: pramsey | Owner: mcayland
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 1.5.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Changes (by mcayland):
* status: new => closed
* resolution: => fixed
Comment:
I believe this is now fixed in 1.4 branch (r4902) and trunk (r4906). The
short story is that due to the way the parser works, not all objects hold
position information and so trying to display the error message was
causing the crash. I've since altered the pop() function to ensure that
the position is stored correctly in so-called "counting tuples" and then
rebased the check functions to use these instead, except for the
continuous curve check which seems to work slightly differently.
Please give this a thorough test as I'm slightly concerned that I may have
missed a few cases.
Paul: I totally agree with you - this took much longer than it really
should have done. I'll be the first one there standing in line with a
pitchfork when the revolution comes.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/316#comment:4>
