[postgis-devel] [PostGIS] #273: ST_GeomFromGML crashes in Windows compiled in MingW
trac at osgeo.org
Fri Nov 27 06:25:47 PST 2009
Reporter: robe | Owner: colivier
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Olivier,
Okay your postgis.dll works. I see one major difference now. You have
the libxml statically compiled into the postgis.dll so your file is 4.9mb
(you have proj statically compiled too bTW) while mine is under a
megabyte. I think the stories I was seeing about crashing were with
dynamically linked like what I was doing.
1) How do you create a statically linked version -- I thought I tried but
maybe I didn't -- can you give me your compile statement for libxml2 and
postgis.
2) From a licensing standpoint -- is there an issue with statically
compiling in the libxml. It does create one less dependency -- though a
heftier postgis.dll. Probably adds another 1 megabyte to the postgis.dll
file which its small anyway.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/273#comment:21>
