[postgis-devel] [PostGIS] #273: ST_GeomFromGML crashes in Windows compiled in MingW
trac at osgeo.org
Sun Nov 29 09:06:57 PST 2009
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Changes (by robe):
* owner: colivier => robe
* status: new => assigned
Comment:
Mark,
Yap I did and had deleted all of them (except the one provided by EDB)
(that fixed my inability to statically link). But still doesn't work when
dynamically linking. I ended up just statically linking and that works
fine. Latest experimental builds have it statically linked in.
I figure its safer anyway since PostgreSQL at least the windows version
uses libxml2 also though they name it differently
so if you are okay with the static solution feel free to close this out.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/273#comment:24>
