[postgis-devel] [PostGIS] #253: Gist causes wrong result from ~=
trac at osgeo.org
Thu Oct 1 01:29:20 PDT 2009
Reporter: nicklas | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version: 1.4.X
Resolution: | Keywords:
Comment (by nicklas):
I have changed the test-table. Now it is more obvious that it by some
reason only compares the boundingboxes for two particular polygons in the
where-part but comparing as expected vertex to vertes in the select-part.
The new testset only contains the result of st_envelope expect for the
problematic polygons where I have edited the envelope-boxes without
affecting their bboxes.
If it, as I think, is a gist-bug, can it still be PostGIS or is it
PostgreSQL then?
/Nicklas
Ticket URL: <http://trac.osgeo.org/postgis/ticket/253#comment:1>
