[postgis-devel] [PostGIS] #253: Gist causes wrong result from ~=
trac at osgeo.org
Fri Oct 2 06:35:20 PDT 2009
Reporter: nicklas | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version: 1.4.X
Resolution: | Keywords:
Comment (by robe):
Here is the ST_OrderingEquals definition -- note that it too might be
broken (without the recheck) if its inlined
CREATE OR REPLACE FUNCTION st_orderingequals(geometry, geometry)
RETURNS boolean AS
$BODY$
SELECT $1 && $2 AND $1 ~= $2
$BODY$
LANGUAGE 'sql' IMMUTABLE STRICT
Ticket URL: <http://trac.osgeo.org/postgis/ticket/253#comment:14>
