[postgis-devel] EMPTY
Paul Ramsey
pramsey at cleverelephant.ca
Tue Oct 6 13:39:14 PDT 2009
In the spirit of maintaining the geometry logical flow, what do you
think of these ideas?
* ST_Contains(geometry, empty) == TRUE
* ST_Within(geometry, empty) == FALSE
* ST_Contains(empty, geometry) == FALSE
* ST_Within(empty, geometry) == TRUE
What does SQL Server say?
P
On Tue, Oct 6, 2009 at 1:34 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> I'm going to change my intersection/disjoint answers to agree w/ SQL
> Server. They are not bad, and they maintain the symmetry between where
> intersection => ! disjoint.
> P.
> On Tue, Oct 6, 2009 at 12:45 PM, Chris Hodgson <chodgson at refractions.net> wrote:
>> I moved these and summarized the interesting results from SQL Server 2008
>> next to your original lines Paul.
>> Note that SQL Server says that everything is disjoint from empty, including
>> empty itself - whereas your original guesses were to return false.
>> So far I think I like SQL Server's answers. Would be good to compare with
>> oracle spatial too.
>> Chris
>> Paul Ramsey wrote:
>>> Regina, could you move your SQL Server examples down to a big block at
>>> the end, so the main part of the document is more readable? So far I
>>> agree with SQL Server in all the examples! Those guys are smart! :)
>>> P
>>> On Tue, Oct 6, 2009 at 12:12 PM, Paul Ramsey <pramsey at cleverelephant.ca>
>>> wrote:
>>>> On Tue, Oct 6, 2009 at 12:03 PM, Chris Hodgson <chodgson at refractions.net>
>>>> wrote:
>>>>> I would dare say that geometry empty is more like zero, than null.
>>>> Bingo, there's a useful mental model. Wikify that!
>>> postgis-devel mailing list
>>> postgis-devel at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
