[postgis-devel] EMPTY
Paul Ramsey pramsey at cleverelephant.ca
Tue Oct 6 14:19:21 PDT 2009
OK, the uber question (Kevin can meditate over this one tonight):
ST_Relate(geometry, empty)
ST_Relate(empty, empty)
On Tue, Oct 6, 2009 at 2:11 PM, Paragon Corporation <lr at pcorp.us> wrote:
> Yap 0 on all counts.  Wow those Microsoft people are really smart.
>  --geometry contains empty
>  SELECT Geometry::STGeomFromText('POINT(1
> 2)',4326).STContains(Geometry::STGeomFromText('POLYGON EMPTY',4326))
>        => 0
> --geometry within empty
> 2)',4326).STWithin(Geometry::STGeomFromText('POLYGON EMPTY',4326))
>         => 0
> --empty contains geometry
>  SELECT Geometry::STGeomFromText('POLYGON
> EMPTY',4326).STContains(Geometry::STGeomFromText('POINT(1 2)',4326))
>  => 0
>  --empty within geometry
> EMPTY',4326).STWithin(Geometry::STGeomFromText('POINT(1 2)',4326))
>  => 0
> Thanks,
> Regina
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Chris
> Hodgson
> Sent: Tuesday, October 06, 2009 5:03 PM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] EMPTY
> I agree with you Regina, and I bet SQL Server does too.
> Chris
> Paragon Corporation wrote:
>> They should all be false.
>> Isn't the first requirement of containment/contains be that the two
>> geometries intersect -- so if we say empty can't intersect with
>> anything including empty, how can anything possibly contain  it?
>> Though have to pull out my sql server 2008 to see if it is in agreement.
>> Thanks,
>> Regina
>> Paul Ramsey
>> Sent: Tuesday, October 06, 2009 4:39 PM
>> In the spirit of maintaining the geometry logical flow, what do you
>> think of these ideas?
>>  * ST_Contains(geometry, empty) == TRUE
>>  * ST_Within(geometry, empty) == FALSE
>>  * ST_Contains(empty, geometry) == FALSE
>>  * ST_Within(empty, geometry) == TRUE
>> What does SQL Server say?
>> P
>> On Tue, Oct 6, 2009 at 1:34 PM, Paul Ramsey
>> <pramsey at cleverelephant.ca>
>> wrote:
>>> I'm going to change my intersection/disjoint answers to agree w/ SQL
>>> Server. They are not bad, and they maintain the symmetry between
>>> where intersection => ! disjoint.
>>> P.
>>> On Tue, Oct 6, 2009 at 12:45 PM, Chris Hodgson
>>> <chodgson at refractions.net>
>> wrote:
>>>> I moved these and summarized the interesting results from SQL Server
>>>> 2008 next to your original lines Paul.
>>>> Note that SQL Server says that everything is disjoint from empty,
>>>> including empty itself - whereas your original guesses were to
>>>> return
>> false.
>>>> So far I think I like SQL Server's answers. Would be good to compare
>>>> with oracle spatial too.
>>>> Chris
>>>> Paul Ramsey wrote:
>>>>> Regina, could you move your SQL Server examples down to a big block
>>>>> at the end, so the main part of the document is more readable? So
>>>>> far I agree with SQL Server in all the examples! Those guys are
>>>>> smart! :)
>>>>> P
>>>>> On Tue, Oct 6, 2009 at 12:12 PM, Paul Ramsey
>>>>> wrote:
>>>>>> On Tue, Oct 6, 2009 at 12:03 PM, Chris Hodgson
>>>>>> wrote:
>>>>>>> I would dare say that geometry empty is more like zero, than null.
>>>>>> Bingo, there's a useful mental model. Wikify that!
>>>>> _______________________________________________
>>>>> postgis-devel mailing list
>>>>> postgis-devel at postgis.refractions.net
>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
