[postgis-devel] EMPTY
Martin Davis
mbdavis at refractions.net
Tue Oct 6 14:30:53 PDT 2009
Yes, I replied too soon - after I realized that ST_relate returns the
matrix,not a boolean result.
But yes, I think FFFFFFFFF is the most reasonable return value.
BTW, I'm thinking of changing JTS so that it returns a more readable
format for the pattern - eg FFF.FFF.FFF (recognized where I got that idea?)
BTW2, the PG doc for ST_relate looks a little confusing to me. It lists
the ST_relate methods in the order (2 args => text, 3 args ==> boolean),
but then goes on to say "Version 1 returns BOOLEAN....)
Paul Ramsey wrote:
> Meaning FFFFFFFFF ? :)
> On Tue, Oct 6, 2009 at 2:25 PM, Martin Davis <mbdavis at refractions.net> wrote:
>> FALSE!!!!
>> Paul Ramsey wrote:
>>> OK, the uber question (Kevin can meditate over this one tonight):
>>> ST_Relate(geometry, empty)
>>> ST_Relate(empty, empty)
>>> On Tue, Oct 6, 2009 at 2:11 PM, Paragon Corporation <lr at pcorp.us> wrote:
>>>> Yap 0 on all counts. Wow those Microsoft people are really smart.
>>>> --geometry contains empty
>>>> SELECT Geometry::STGeomFromText('POINT(1
>>>> 2)',4326).STContains(Geometry::STGeomFromText('POLYGON EMPTY',4326))
>>>> => 0
>>>> --geometry within empty
>>>> 2)',4326).STWithin(Geometry::STGeomFromText('POLYGON EMPTY',4326))
>>>> => 0
>>>> --empty contains geometry
>>>> SELECT Geometry::STGeomFromText('POLYGON
>>>> EMPTY',4326).STContains(Geometry::STGeomFromText('POINT(1 2)',4326))
>>>> => 0
>>>> --empty within geometry
>>>> EMPTY',4326).STWithin(Geometry::STGeomFromText('POINT(1 2)',4326))
>>>> => 0
>>>> Thanks,
>>>> Regina
>>>> -----Original Message-----
>>>> From: postgis-devel-bounces at postgis.refractions.net
>>>> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Chris
>>>> Hodgson
>>>> Sent: Tuesday, October 06, 2009 5:03 PM
>>>> To: PostGIS Development Discussion
>>>> Subject: Re: [postgis-devel] EMPTY
>>>> I agree with you Regina, and I bet SQL Server does too.
>>>> Chris
>>>> Paragon Corporation wrote:
>>>>> They should all be false.
>>>>> Isn't the first requirement of containment/contains be that the two
>>>>> geometries intersect -- so if we say empty can't intersect with
>>>>> anything including empty, how can anything possibly contain it?
>>>>> Though have to pull out my sql server 2008 to see if it is in agreement.
>>>>> Thanks,
>>>>> Regina
>>>>> Paul Ramsey
>>>>> Sent: Tuesday, October 06, 2009 4:39 PM
>>>>> In the spirit of maintaining the geometry logical flow, what do you
>>>>> think of these ideas?
>>>>> * ST_Contains(geometry, empty) == TRUE
>>>>> * ST_Within(geometry, empty) == FALSE
>>>>> * ST_Contains(empty, geometry) == FALSE
>>>>> * ST_Within(empty, geometry) == TRUE
>>>>> What does SQL Server say?
>>>>> P
>>>>> On Tue, Oct 6, 2009 at 1:34 PM, Paul Ramsey
>>>>> <pramsey at cleverelephant.ca>
>>>>> wrote:
>>>>>> I'm going to change my intersection/disjoint answers to agree w/ SQL
>>>>>> Server. They are not bad, and they maintain the symmetry between
>>>>>> where intersection => ! disjoint.
>>>>>> P.
>>>>>> On Tue, Oct 6, 2009 at 12:45 PM, Chris Hodgson
>>>>>> <chodgson at refractions.net>
>>>>> wrote:
>>>>>>> I moved these and summarized the interesting results from SQL Server
>>>>>>> 2008 next to your original lines Paul.
>>>>>>> Note that SQL Server says that everything is disjoint from empty,
>>>>>>> including empty itself - whereas your original guesses were to
>>>>>>> return
>>>>> false.
>>>>>>> So far I think I like SQL Server's answers. Would be good to compare
>>>>>>> with oracle spatial too.
>>>>>>> Chris
>>>>>>> Paul Ramsey wrote:
>>>>>>>> Regina, could you move your SQL Server examples down to a big block
>>>>>>>> at the end, so the main part of the document is more readable? So
>>>>>>>> far I agree with SQL Server in all the examples! Those guys are
>>>>>>>> smart! :)
>>>>>>>> P
>>>>>>>> On Tue, Oct 6, 2009 at 12:12 PM, Paul Ramsey
>>>>>>>> wrote:
>>>>>>>>> On Tue, Oct 6, 2009 at 12:03 PM, Chris Hodgson
>>>>>>>>> wrote:
>>>>>>>>>> I would dare say that geometry empty is more like zero, than null.
>>>>>>>>> Bingo, there's a useful mental model. Wikify that!
>>>>>>>> _______________________________________________
>>>>>>>> postgis-devel mailing list
>>>>>>>> postgis-devel at postgis.refractions.net
>>>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>> Martin Davis
>> Senior Technical Architect
>> Refractions Research, Inc.
>> (250) 383-3022
Martin Davis
(250) 383-3022
