[postgis-devel] [PostGIS] #260: Geography inconsistent distance behavior from geometry and geography flag counting flaky
PostGIS trac at osgeo.org
Fri Oct 9 09:38:15 PDT 2009
counting flaky
  Reporter:  robe     |       Owner:  pramsey
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  postgis 1.5.0
 Component:  postgis  |     Version:
Resolution:           |    Keywords:
Changes (by robe):
  * summary:  Geography inconsistent distance behavior from geometry can't
              compare different dimensonality => Geography
Comment:
 If we are not going to allow this - gives gbox_overlaps: geometries have
 mismatched dimensionality:
 SELECT ST_Distance(ST_GeographyFromText('SRID=4326;POINT(-10 50)'),
                         ST_GeographyFromText('SRID=4326;LINESTRING(-10 40
 1,-9 41 1)'));
 Then we certainly shouldn't be allowing this which happens to work.
 SELECT ST_Distance(ST_GeographyFromText('SRID=4326;POINT(-10 50 1)'),
                         ST_GeographyFromText('SRID=4326;LINESTRINGM(-10 40
 1,-9 41 1)'));
Ticket URL: <http://trac.osgeo.org/postgis/ticket/260#comment:6>
