[postgis-devel] [PostGIS] #264: CUnit geography suite failures
PostGIS trac at osgeo.org
Sun Oct 11 09:08:04 PDT 2009
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  postgis 1.5.0
Component:  postgis  |     Version:
 Keywords:           |
 I'm seeing more of a pattern between GCC than OS as to how this fails.  As
 I mentioned I found it strange that one of my OpenSUSE vms fails more like
 one of my MingWs.  In fact teh OpenSUSEs fail in different ways.  It
 occurred to me that what the similarities are between the like
 MingW/OpenSuse pairs I believe to be version of GCC.  I'll have to double-
 check since I don't have those available at the moment.
 Here is what I have
 CUnit geography failures on various mixins of OpenSuse, MingW, GCC
 --On one Windows XP MingW running gcc.exe (GCC) 3.4.5 (mingw-vista special
 r3)
 Suite: Geodetic Suite
   Test: test_signum() ... passed
   Test: test_gbox_from_spherical_coordinates() ... passed
   Test: test_gserialized_get_gbox_geocentric() ... passed
   Test: test_clairaut() ... passed
   Test: test_edge_intersection() ... FAILED
         1. cu_geodetic.c:375  - CU_ASSERT_EQUAL(rv,LW_TRUE)
         2. cu_geodetic.c:383  - CU_ASSERT_EQUAL(rv,LW_TRUE)
   Test: test_edge_distance_to_point() ... passed
   Test: test_edge_distance_to_edge() ... passed
   Test: test_lwgeom_distance_sphere() ... passed
   Test: test_ptarray_point_in_ring() ... passed
 --On other MingW running (I thinkg gcc 4.11  -- have to double-check - I
 know I upgraded this one to newest MingW gcc)
 Don't have stats but recall it fails like my OpenSuse 11.0 VM
 -- On OpenSuse 10.3 fails same as first MingW - have to double-check gcc
 but think its in the 3. something series
 -- On OpenSuse 11.0 vM  fails as my second MingW runnning new gcc
 -- gcc (SUSE Linux) 4.3.1 20080507 (prerelease) [gcc-4_3-branch revision
 135036]
         1. cu_geodetic.c:324  - CU_ASSERT_DOUBLE_EQUAL(g.lon,0.0,0.00001)
         2. cu_geodetic.c:325  - CU_ASSERT_EQUAL(rv,LW_TRUE)
         3. cu_geodetic.c:340  - CU_ASSERT_DOUBLE_EQUAL(g.lon,0.0,0.00001)
         4. cu_geodetic.c:341  - CU_ASSERT_EQUAL(rv,LW_TRUE)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/264>
