[postgis-devel] [PostGIS] #264: CUnit geography suite failures
trac at osgeo.org
Tue Oct 13 04:18:27 PDT 2009
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Was a bit wrong about the gcc on my OpenSUSE 10.3 and MingW they are both
newer than I thought. Latest results against trunk for both these are
below.
So I guess if its a GCC issue, its something that changed between GCC 4.2
and GCC 4.3
gcc --version --> gcc (GCC) 4.2.1 (SUSE Linux)
Suite: Geodetic Suite
Test: test_signum() ... passed
Test: test_gbox_from_spherical_coordinates() ... passed
Test: test_gserialized_get_gbox_geocentric() ... passed
Test: test_clairaut() ... passed
Test: test_edge_intersection() ... FAILED
1. cu_geodetic.c:375 - CU_ASSERT_EQUAL(rv,LW_TRUE)
2. cu_geodetic.c:383 - CU_ASSERT_EQUAL(rv,LW_TRUE)
Test: test_edge_distance_to_point() ... passed
Test: test_edge_distance_to_edge() ... passed
Test: test_lwgeom_distance_sphere() ... passed
Test: test_ptarray_point_in_ring() ... passed
My MingW running the newer gcc compiling against latest trunk
gcc --version --> gcc.exe (GCC) 4.4.0
1. cu_geodetic.c:324 - CU_ASSERT_DOUBLE_EQUAL(g.lon,0.0,0.00001)
2. cu_geodetic.c:325 - CU_ASSERT_EQUAL(rv,LW_TRUE)
3. cu_geodetic.c:340 - CU_ASSERT_DOUBLE_EQUAL(g.lon,0.0,0.00001)
4. cu_geodetic.c:341 - CU_ASSERT_EQUAL(rv,LW_TRUE)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/264#comment:3>
