[postgis-devel] [PostGIS] #268: Simple intersection query between geography column and POLYGON geography fails
trac at osgeo.org
Thu Oct 15 07:08:04 PDT 2009
fails
Reporter: mcayland | Owner: mcayland
Type: defect | Status: new
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version:
Resolution: | Keywords:
Comment (by robe):
This is strange. I think its a bug in the bbox creation than the operator
itself that for some reason the bbox being created is a geometry and not
geography.
It works fine when I convert a geometry to geography on the fly like so
or maybe its not creating a bbox in this case.
explain select count(*) from neighborhoods
where geography(ST_Transform(the_geom,4326)) &&
ST_GeographyFromText('POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))');
-- but doesn't work with below
SELECT name, geography(ST_Transform(the_geom,4326)) As the_geog
INTO nei_geography
FROM neighborhoods ;
explain select count(*) from nei_geography where the_geog &&
Ticket URL: <http://trac.osgeo.org/postgis/ticket/268#comment:1>
