[postgis-devel] FLAGS_SET_* macros in libgeom.h don't actually set the value
Paul Ramsey
pramsey at cleverelephant.ca
Thu Oct 15 08:00:54 PDT 2009
And for initializations, note the gflags() function hiding in the corner.
P
On Thu, Oct 15, 2009 at 8:00 AM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> Harmonize away.
> P
> On Thu, Oct 15, 2009 at 7:58 AM, Mark Cave-Ayland
> <mark.cave-ayland at siriusit.co.uk> wrote:
>> Hi all,
>> In the new geography code, I've been tripped up a couple of times doing
>> something like this:
>> FLAGS_SET_GEODETIC(search_box.flags, 1);
>> if (!lwgeom_calculate_gbox_geodetic(geometry, &search_box))
>> Contrary to popular belief, the FLAGS_SET_GEODETIC() macro doesn't actually
>> *set* the search_box geodetic flag, but merely returns what the flags
>> parameter should be once the geodetic flag has been set. So at the moment,
>> you must remember to do something like this:
>> search_box.flags = FLAGS_SET_GEODETIC(search_box.flags, 1);
>> This behaviour seems to go against general convention, especially in that
>> the PostgreSQL macros such as SET_VARSIZE() change the variable directly.
>> Would anyone mind if I go through the geography code and alter the
>> FLAGS_SET_* macros and callees so that we don't need this additional
>> assignment at the front?
>> ATB,
>> Mark.
>> Mark Cave-Ayland - Senior Technical Architect
>> PostgreSQL - PostGIS
>> Sirius Corporation plc - control through freedom
>> http://www.siriusit.co.uk
>> t: +44 870 608 0063
>> Sirius Labs: http://www.siriusit.co.uk/labs
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
