[postgis-devel] [PostGIS] #231: New distance-calculations proposal
PostGIS trac at osgeo.org
Sun Oct 18 23:26:05 PDT 2009
  Reporter:  nicklas      |       Owner:  robe
      Type:  enhancement  |      Status:  assigned
  Priority:  medium       |   Milestone:  postgis 1.5.0
 Component:  postgis      |     Version:
Resolution:               |    Keywords:
Comment (by nicklas):
 I think the reason, sql server gets the same answer as postgis of today is
 because they do the exactly same calculation.
 It is described here:
 http://www.faqs.org/faqs/graphics/algorithms-faq/
 and can be found by searching for:
 "Subject 1.02: How do I find the distance from a point to a line?"
 So what postgis does today and apperently also sql server is to calculate
 the distance directly from the point to the line. A little bit further
 down in the text in the link it is described how to find the point on the
 line to where the distance is calculated. The thing then is that the point
 has the same "bad" precision as the original inputed vertexes wich dives a
 slightly different answer. That is no problem because the extra precision
 in the distance-answer makes no sense since the vertexes is inaccurate.
 But then we know some more about the sql-server code :-). They have not
 prepared it for shortestline function I guess.
 I think it is a strength if the distance-calculation gives exactly the
 same answer as the length of the shortest line and that I think should be
 the case now.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/231#comment:21>
