[postgis-devel] [PostGIS] #231: New distance-calculations proposal
trac at osgeo.org
Mon Oct 19 05:50:36 PDT 2009
Reporter: nicklas | Owner: robe
Type: enhancement | Status: assigned
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version:
Resolution: | Keywords:
Comment (by nicklas):
For the record
ST_ClosestPoint(A,B) => SELECT ST_StartPoint(ST_ShortestLine(A,B));
ST_FurthestPoint(A,B) => SELECT ST_StartPoint(ST_LongestLine(A,B));
above should be
ST_ClosestPoint(A,B) => SELECT ST_EndPoint(ST_ShortestLine(A,B));
ST_FurthestPoint(A,B) => SELECT ST_EndPoint(ST_LongestLine(A,B));
if I don't missunderstand you Regina.[[BR]]
Then you get the closest and most far point in geometry B, from geometry
A[[BR]]
from the today definition of shortest and longest line.
[[BR]]
Here might be a small problem in what people ecpect. closest point is no
problem I thing but frthest point might give the impression that it is the
point most fas from geometry A but it is the most far away point in
geometry B from the most far away point in geometry A.
Maybe it is only closest point that is of real interest? To avoid
missunderstanding.
Or maybe closest and furthest points should be the beginning and the end
of shortest line instead? like this:
ST_FurthestPoint(A,B) => SELECT ST_EndPoint(ST_ShortestLine(A,B));
Then closestPoint is a point on geometry A and furthestPoint is a point on
geometry B.
[[BR]]
Ticket URL: <http://trac.osgeo.org/postgis/ticket/231#comment:26>
