[postgis-devel] RES: postgis-devel Digest, Vol 75, Issue 43
Jairo de Almeida
jairo.almeida at gempi.com.br
Tue Oct 27 12:49:24 PDT 2009
To com saudade da minha lorinha linda
Poxa vida
Saudadeeeeeeeeeeeeeeeeeeee
-----Mensagem original-----
De: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] Em nome de
postgis-devel-request at postgis.refractions.net
Enviada em: terça-feira, 27 de outubro de 2009 17:00
Para: postgis-devel at postgis.refractions.net
Assunto: postgis-devel Digest, Vol 75, Issue 43
Send postgis-devel mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://postgis.refractions.net/mailman/listinfo/postgis-devel
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
postgis-devel-owner at postgis.refractions.net
When replying, please edit your Subject line so it is more specific than
"Re: Contents of postgis-devel digest..."
Today's Topics:
1. Re: [PostGIS] #273: ST_GeomFromGML crashes in Windows
compiled in MingW (PostGIS)
2. [PostGIS] #275: documentation still points to Google
bug-tracker (PostGIS)
Message: 1
Date: Mon, 26 Oct 2009 21:38:20 -0000
Subject: Re: [postgis-devel] [PostGIS] #273: ST_GeomFromGML crashes in
Windows compiled in MingW
Cc: postgis-devel at postgis.refractions.net
Message-ID: <055.a7e1988923afa659fff4e906e089466c at osgeo.org>
Content-Type: text/plain; charset="utf-8"
#273: ST_GeomFromGML crashes in Windows compiled in MingW
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Olivier,
Sorry for taking so long to get back to you. Under a lot of time
pressures with other projects this week so you probably won't here much
from me for at least another week or 2.
Regarding the attached. It doesn't compile for me at all. Gives errors
like
lwgeom_in_gml.c:2179: warning: type defaults to `int' in declaration of
`name'
lwgeom_in_gml.c:2179: error: syntax error before '<' token
lwgeom_in_gml.c:2181: warning: type defaults to `int' in declaration of
`name'
lwgeom_in_gml.c:2181: error: syntax error before '<' token
lwgeom_in_gml.c:2183: warning: type defaults to `int' in declaration of
`name'
lwgeom_in_gml.c:2183: error: syntax error before '<' token
lwgeom_in_gml.c:2185: warning: type defaults to `int' in declaration of
`name'
lwgeom_in_gml.c:2185: error: syntax error before '<' token
lwgeom_in_gml.c:2187: warning: type defaults to `int' in declaration of
`name'
lwgeom_in_gml.c:2187: error: syntax error before '<' token
lwgeom_in_gml.c:2189: warning: type defaults to `int' in declaration of
`name'
lwgeom_in_gml.c:2189: error: syntax error before '<' token
lwgeom_in_gml.c:2195: warning: type defaults to `int' in declaration of
`geom'
lwgeom_in_gml.c:2195: error: redefinition of 'geom'
lwgeom_in_gml.c:2173: error: previous definition of 'geom' was here
lwgeom_in_gml.c:247: error: previous definition of 'geom' was here
lwgeom_in_gml.c:2195: error: syntax error before ')' token
lwgeom_in_gml.c:2197: error: syntax error before ')' token
lwgeom_in_gml.c:2223: warning: type defaults to `int' in declaration of
`xa'
lwgeom_in_gml.c:2223: error: redefinition of 'xa'
lwgeom_in_gml.c:2149: error: previous definition of 'xa' was here
lwgeom_in_gml.c:1401: error: previous definition of 'xa' was here
lwgeom_in_gml.c:2223: warning: data definition has no type or storage
class
lwgeom_in_gml.c:2223: error: syntax error before '<' token }}}
and goes on and on. The gml in BTW works fine on my OpenSUSE 10.3 (using
the same libxml source) (haven't tried my more finicky 11). Even going
thru the gardent test seems to work fine.
I think its an issue with compiling libxml2 under mingW. I searched, and
it seems stories are the same with the libxml crashing when compiled under
mingw. Possibly threading issues or something. the compile of libxml2
also gives a ton of warnings about exceeded length of the form
.libs/lt-testModule.c:285: warning: string length `1611' is greater than
the length `509' ISO C89 compilers are required to support
So I fear this may be beyond my abilities to solve. Perhaps Mark can take
a stab at it when he has the time to see if there is a trick to getting
this to behave correctly.
My newer mingw 4.4 compiler refuses to even compile the libxml2.
Thanks,
Regina
Ticket URL: <http://trac.osgeo.org/postgis/ticket/273#comment:2>
PostGIS <http://trac.osgeo.org/postgis/> PostGIS
Message: 2
Date: Tue, 27 Oct 2009 07:42:16 -0000
Subject: [postgis-devel] [PostGIS] #275: documentation still points to
Google bug-tracker
Message-ID: <049.28cabc84dff8a0f3c9b271f1643c1746 at osgeo.org>
#275: documentation still points to Google bug-tracker
Reporter: nicklas | Owner: pramsey
Keywords: |
All documentation still points to Google bug-tracker in chapter "Reporting
Software Bugs"
ch 7 or 9
Ticket URL: <http://trac.osgeo.org/postgis/ticket/275>
End of postgis-devel Digest, Vol 75, Issue 43
__________ NOD32 2047 (20070208) Information __________
This message was checked by NOD32 antivirus system.
http://www.eset.com
