[postgis-devel] [PostGIS] #280: in_gml regression test fails
trac at osgeo.org
Fri Oct 30 06:04:55 PDT 2009
Reporter: mloskot | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
That's interesting. For what its worth, I finally got around to running
it on my OpenSUSE 11 vm (32-bit) last night and it worked fine using the
same ftp://xmlsoft.org/libxml2/libxml2-sources-2.7.6.tar.gz I was using on
my mingW. Even garden tests well returned geometries didn't verify they
were right.
Mateusz, which version of libxml2 were you compiling against.
The reason I thought my mingW libxml2 compile was at fault was because
even the test exes that get built by libxml2 would hang too.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/280#comment:1>
