[postgis-devel] [PostGIS] #279: hausdorff regression test fails
trac at osgeo.org
Fri Oct 30 06:16:45 PDT 2009
Reporter: mloskot | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords: hausdorff
Comment (by robe):
I wonder if this is related to #258 though Mark had fixed this and I
believe he is running 64-bit so must have worked for him.
Can you check (ST_LineCrossingDirection)
http://www.postgis.org/documentation/manual-
svn/ST_LineCrossingDirection.html
Since that had similar issues too. I haven't tested against the latest
GEOS trunk so that might be something else.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/279#comment:2>
