[postgis-devel] [PostGIS] #280: in_gml regression test fails
trac at osgeo.org
Fri Oct 30 08:04:28 PDT 2009
Reporter: mloskot | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Old description:
> Running regression tests against PostGIS from current trunk (r4706) gives
> failure for the ''in_gml'' test
> in_gml. failed (diff expected obtained:
> /tmp/pgis_reg_27721/test_45_diff)
> and it looks it crashes the server
> $ tail -n 2 /tmp/pgis_reg_27721/test_45_diff
> --- 1 ----
> ! psql: FATAL: the database system is in recovery mode
> I did full rebuild of both, PostGIS and GEOS.
> Full test log attached.
> The problem may be related to bug reported in #273.
> Environment:
> * Linux 64-bit
> * GCC 4.4.1
> * GEOS (version 3.2.0 from SVN trunk
> [http://trac.osgeo.org/geos/changeset/2710 2710])
New description:
in_gml. failed (diff expected obtained: /tmp/pgis_reg_27721/test_45_diff)
--- 1 ----
Environment:
* Linux 64-bit (Ubuntu 9.10 Karmic Koala)
* GCC 4.4.1
* libxml2 2.7.5
Comment (by mloskot):
I use libxml2 2.7.5 installed from Ubuntu 9.10 packages
Here is output of the commands:
* ldd
$ ldd /usr/lib/postgresql/8.4/lib/postgis-1.5.so
linux-vdso.so.1 => (0x00007ffffc7d1000)
libgeos_c.so.1 => /usr/local/lib/libgeos_c.so.1
(0x00007f28c74bd000)
libproj.so.0 => /usr/lib/libproj.so.0 (0x00007f28c727c000)
libxml2.so.2 => /usr/lib/libxml2.so.2 (0x00007f28c6f2d000)
libc.so.6 => /lib/libc.so.6 (0x00007f28c6bbe000)
libgeos-3.2.0.so => /usr/local/lib/libgeos-3.2.0.so
(0x00007f28c66bd000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00007f28c63ac000)
libm.so.6 => /lib/libm.so.6 (0x00007f28c6128000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00007f28c5f11000)
libdl.so.2 => /lib/libdl.so.2 (0x00007f28c5d0c000)
libz.so.1 => /lib/libz.so.1 (0x00007f28c5af5000)
/lib64/ld-linux-x86-64.so.2 (0x00007f28c7986000)
* xml2config
mloskot at vb-ubuntu910-x64:~/dev/postgis/_svn/trunk$ xml2config --version
No command 'xml2config' found, did you mean:
Command 'xml2-config' from package 'libxml2-dev' (main)
xml2config: command not found
mloskot at vb-ubuntu910-x64:~/dev/postgis/_svn/trunk$ xml2-config --version
2.7.5
mloskot at vb-ubuntu910-x64:~/dev/postgis/_svn/trunk$ ./configure | grep xml
checking for xml2-config... /usr/bin/xml2-config
checking libxml/tree.h usability... yes
checking libxml/tree.h presence... yes
checking for libxml/tree.h... yes
checking libxml/parser.h usability... yes
checking libxml/parser.h presence... yes
checking for libxml/parser.h... yes
checking for xmlInitParser in -lxml2... yes
Libxml2 config: /usr/bin/xml2-config
Libxml2 version: 2.7.5
Ticket URL: <http://trac.osgeo.org/postgis/ticket/280#comment:4>
