[postgis-devel] [PostGIS] #202: upgrade issues
trac at osgeo.org
Tue Sep 1 09:05:36 PDT 2009
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: medium | Milestone: postgis 1.4.1
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Here is a revised patch to trunk postgis.in.sql.c.
This does both upgrade as well as doing a fresh install. Unfortunately it
seems that the way I did it totally confuses the postgis_upgrade.sql
generator.
This does what I described above, but I tested it by upgrading a postgis
1.4 to 1.5 and creating a postgis 1.5 fresh. Have to find my old 1.3 data
to test upgrading, but should work since it recreates aggregates, but only
creates types if they don't already exist.
I was thinking we can make it smarter by when we decide to rename
everything check which functions are used in a type and if we don't like
the name, rename the function to the new name (of course dropping the new
name).. Haven't attempted that.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/202#comment:22>
