[postgis-devel] updating version of wktraster
Jeff Hamann
jeff.hamann at forestinformatics.com
Fri Sep 4 18:43:02 PDT 2009
I checked out and built the wktraster/gdal-1.7dev (I think) and see
that the wkt_version that is returned by the postgis_raster_lib_version
() function is still 3949, is that the correct version since the
postgis_raster_lib_build_date() returns the actual date it was built.
The lib_version() seems to have not changed since June. Is that correct?
Here's are my current values:
-[ RECORD 1 ]----------
current_database | rufus
current_user | hamannj
postgres_version | PostgreSQL 8.3.5 on i386-apple-darwin9.6.0,
compiled by GCC i686-apple-darwin9-gcc-4.0.1 (GCC) 4.0.1 (Apple Inc.
build 5465)
postgis_version | POSTGIS="1.5.0SVN" GEOS="3.0.0-CAPI-1.4.1"
PROJ="Rel. 4.6.1, 21 August 2008" USE_STATS
wkt_version | : 3949 $
wkt_version_build_date | 2009-08-28 19:30:56
r_version | R version 2.9.1 (2009-06-26)
Thanks,
Jeff.
Jeff Hamann, PhD
PO Box 1421
Corvallis, Oregon 97339-1421
541-754-2457
jeff.hamann[at]forestinformatics[dot]com
http://www.forestinformatics.com
