[postgis-devel] python manage.py syncdb
Zico
mailzico at gmail.com
Fri Sep 11 12:36:03 PDT 2009
I have been trying to configure a package. In one Command is: *python
manage.py syncdb
*But, here, i get the error: Apnar help lagbe boss!!! :(
*psycopg2.InternalError: current transaction is aborted, commands ignored
until end of transaction block
Here is the full error:
[root at fedora fixmystreet]# python manage.py syncdb
local_settings.py not set; using default settings
File "manage.py", line 11, in <module>
execute_manager(settings)
File "/usr/lib/python2.6/site- packages/django/core/management/__init__.py",
line 362, in execute_manager
utility.execute()
File
"/usr/lib/python2.6/site-packages/django/core/management/__init__.py", line
303, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File "/usr/lib/python2.6/site-packages/django/core/management/base.py",
line 195, in run_from_argv
self.execute(*args, **options.__dict__)
line 221, in execute
self.validate()
line 249, in validate
num_errors = get_validation_errors(s, app)
File
"/usr/lib/python2.6/site-packages/django/core/management/validation.py",
line 28, in get_validation_errors
for (app_name, error) in get_app_errors().items():
File "/usr/lib/python2.6/site-packages/django/db/models/loading.py", line
131, in get_app_errors
self._populate()
58, in _populate
self.load_app(app_name, True)
74, in load_app
models = import_module('.models', app_name)
File "/usr/lib/python2.6/site-packages/django/utils/importlib.py", line
35, in import_module
__import__(name)
File "/opt/fixmystreet/mainapp/models.py", line 3, in <module>
from django.contrib.gis.db import models
File
"/usr/lib/python2.6/site-packages/django/contrib/gis/db/models/__init__.py",
line 5, in <module>
from django.contrib.gis.db.models.aggregates import *
File
"/usr/lib/python2.6/site-packages/django/contrib/gis/db/models/aggregates.py",
line 2, in <module>
from django.contrib.gis.db.backend import SpatialBackend
File
"/usr/lib/python2.6/site-packages/django/contrib/gis/db/backend/__init__.py",
line 12, in <module>
from django.contrib.gis.db.backend.postgis import
create_test_spatial_db, get_geo_where_clause, SpatialBackend
File
"/usr/lib/python2.6/site-packages/django/contrib/gis/db/backend/postgis/__init__.py",
line 4, in <module>
from django.contrib.gis.db.backend.postgis.adaptor import PostGISAdaptor
File
"/usr/lib/python2.6/site-packages/django/contrib/gis/db/backend/postgis/adaptor.py",
line 5, in <module>
from django.contrib.gis.db.backend.postgis.query import GEOM_FROM_WKB
File
"/usr/lib/python2.6/site-packages/django/contrib/gis/db/backend/postgis/query.py",
line 27, in <module>
version_tuple = postgis_version_tuple()
File
"/usr/lib/python2.6/site-packages/django/contrib/gis/db/backend/postgis/management.py",
line 45, in postgis_version_tuple
version = postgis_lib_version()
File
line 25, in postgis_lib_version
return _get_postgis_func('postgis_lib_version')
File
line 13, in _get_postgis_func
cursor.execute('SELECT %s()' % func)
until end of transaction block*
Best,
Zico
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090912/90959e8b/attachment.html>
