[postgis-devel] st_isvalid() does not return warning message
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Sun Sep 13 07:26:25 PDT 2009
Blake Crosby wrote:
> Maxime,
> Thanks, perhaps I will upgrade!
> So it looks like there is an issue with significant digits, in my view:
> (-108.616666666667 54.2) != (-108.616666666664 54.1999999999825)
> Cause it looks like its rounding up. and treating these two points as one.
> Blake
Alas this is a general problem with floating point numbers, not just
PostGIS - you only get 15-16 significant figures precision within a
64-bit double :(
Even if you could rewrite PostGIS to use doubles > 64-bit, you'd still
need to find suitable hardware support otherwise all floating point
calculations would be terribly slow...
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
