[postgis-devel] [PostGIS] #250: Trunk doesn't compile under MingW because of regex
trac at osgeo.org
Fri Sep 18 07:12:46 PDT 2009
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by mcayland):
Please don't - the fix for the linker flags is just a quick hack. Mainly
because the dependency for regex is actually on liblwgeom and not the .so
module for starters...
My vote would be to remove regex from the code totally - it seems too much
of an overkill for what we're using it for.
ATB,
Mark.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/250#comment:2>
