[postgis-devel] CREATE LANGUAGE in postgis.sql
Kevin Neufeld
kneufeld at refractions.net
Tue Sep 22 09:01:33 PDT 2009
Perfect. That'll do it.
-- Kevin
Paragon Corporation wrote:
> How about something like this
> http://andreas.scherbaum.la/blog/archives/346-create-language-if-not-exist.h
> tml
> Regina
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Kevin
> Neufeld
> Sent: Tuesday, September 22, 2009 11:37 AM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] CREATE LANGUAGE in postgis.sql
> Right. Unfortunately, PostgreSQL doesn't have the CREATE LANGUAGE [IF NOT
> EXISTS] syntax yet, so it'll have to go outside of the transaction block.
> If we put the CREATE LANGUAGE command at the start of the postgis.sql file,
> but outside the block, then the first thing most people will see when they
> install PostGIS is an ERROR message ... could cause a lot of confusion. It
> also means one can't grep the output for ERRORs when performing automatic
> installs.
> ... unless someone can thing of a cleaver way to query the pg_language table
> for the existence of 'plpgsql' and execute the create language statement
> appropriately ...
> -- Kevin
> Mark Cave-Ayland wrote:
>> Paul Ramsey wrote:
>>> In answer to me, it's an ERROR so the transaction block will fail
>>> unless we do it outside the block.
>> Yeah, that was along the lines of what I was thinking...
>> ATB,
>> Mark.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
