[postgis-devel] Two questions about wktraster development
Jorge Arévalo
jorge.arevalo at gmail.com
Wed Sep 23 03:36:53 PDT 2009
On Tue, Sep 22, 2009 at 3:11 PM, Mateusz Loskot
<Mateusz.Loskot at cadcorp.com> wrote:
> Jorge Arévalo wrote:
>> Hello everybody,
>> During this summer, I took part in Google Summer of Code, developing
>> the WKT Raster driver for GDAL. After the program, I'm going to carry
>> on with the project. Just now, I'm testing 2 features I couldn't test
>> properly during GSoC. These are out-db raster support and endianess.
>> And I've a couple of questions:
>> - Out-db support: I modified the gdal2wktraster script to add out-db
>> support [1]. I had to "hack" the WKT Raster extension code to allow
>> out-db rasters too. I simply commented the lines 532-535 of
>> $WKTRASTER_SRC/rt_pg/rtpostgis.sql file (out-db checking).
> You probably mean these lines:
> http://trac.osgeo.org/postgis/browser/spike/wktraster/rt_pg/rtpostgis.sql.in.c#L539
Yes, that is.
>> Is it a good way of doing this? Temporarily, of course.
> Yes, it is as long as the out-db support is provided/ready.
Ok. Anyway, I did the change only for testing purposes
>> - Endianess: I tried to insert raster data with different endianess
>> than my machine, but when the INSERT was executed, the endianess was
>> changed to the correct one. At which level does it happen? WKT Raster
>> extension level, PostgreSQL level? I couldn't apply a "hack" here...
> It is correct behaviour.
> You insert data indirectly calling RASTER_in function:
> http://trac.osgeo.org/postgis/browser/spike/wktraster/rt_pg/rt_pg.c#L260
> The first byte of raster WKB stream indicates endianness.
> This flag is used by WKB parser to read "real numbers" from WKB stream:
> http://trac.osgeo.org/postgis/browser/spike/wktraster/rt_core/rt_api.c#L1865
> Then object composed of "real numbers" is serialised
> according to native properties of host machine:
> http://trac.osgeo.org/postgis/browser/spike/wktraster/rt_core/rt_api.c#L2367
> I hope it does make sense.
Of course yes. So, I may change the rt_raster_serialize code to test
this feature.
Many thanks Mateusz!
Best regards,
Jorge
> Best regards,
> Mateusz Loskot
> Senior Programmer, Cadcorp
> http://www.cadcorp.com
> This email is confidential and may be privileged and should not be used,
> read or copied by anyone who is not the original intended recipient. If you
> have received this email in error please inform the sender and delete it
> from your mailbox or any other storage mechanism. Unless specifically
> stated, nothing in this email constitutes an offer by Cadcorp and Cadcorp
> does not warrant that any information contained in this email is accurate.
> Cadcorp cannot accept liability for any statements made which are clearly
> the sender's own and not expressly made on behalf of Cadcorp or one of its
> agents. Please rely on your own virus check. No responsibility is taken by
> Cadcorp for any damage arising out of any bug or virus infection.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
